The HTC Desire HD is an Android smartphone by HTC Corporation.
26 Questions View all
Won't turn on, so replaced motherboard but still won't turn on?
Hi,
HTC Desire HD won't turn on so I replaced the upper part of the motherboard and it still won't turn on.
I think it might be the battery, battery connector, or the charging port as no LED is showing when I plug the charger in?
I've tried to do the hard reset thing a couple of times (power button + volume down) and only once has it shown a red LED but that's all, no sound and screen didn't turn on (screen looks in good condition also).
Don't want to waste any more money buying parts that aren't needed as I already paid ~£20 for a new motherboard so was hoping you guys could help me :)
Also don't know the history of this phone as I bought it off ebay but the water indicators are still white so I don't think it's water damaged.
Thanks,
Brad
Score -1
Add a comment
1 Answer
Most Helpful Answer
did u flash the OS after replacing motherboard...
Score 2
4 Comments:
Can you explain what that is / how to do it? Sorry, I'm new to fixing phones
by
firstly i should know whether ur phone showing any sign while charging..if not make sure that ur phone battery is not dead and power is passing in mother board...if it is done connect it to pc and check in HTC pc suite whether it is detected or not....hope we can fix it...good luck
by
Thanks for the reply.
Phone is showing no sign while charging, no LED or anything. How can I check that battery isn't dead or power is passing through motherboard?
Thanks
by
Check it with MULTIMETER
Your mobile battery have 3v - 5v DC
Place the battery in mobile and check the motherboard sockets whether voltage is varying or not..
If not check all the connections again..If nothing happens better you should take it to HTC support center.
Good Luck
by
Add a comment
Add your answer
Brad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 975
