The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
Why is my battery draining so quick & not charging
So my Samsung Galaxy S3 charger broke and I needed a new charger as soon as possible. Up to this point, my battery life was great, no complaints.
However, this changed when I used the next available charger, which was for an LG flip phone my parents owned. Over time, the battery life became increasingly shortened.When I noticed this, I bought two spare batteries to essentially swap in and out when the other died
I was still using the LG charger at this point and these new batteries still had terrible battery life. Nonetheless, i stuck with the swapping method until i could order an extended battery by digital energy and new samsung charger
I've done this yet the issue remains. The battery still gets drained relatively fast.
I should add, I've bought new and official Samsung chargers for my phone. When plugged to my phone, these chargers do not charge
Im almost positive it is a hardware defect. What should I do?
Score -1
Add a comment
Chosen Solution
Some chargers are electronically not clean at all. Electronical defaults can damage you battery and shorten its life. I recommend you to own and replace both your battery and charger and I HIGHLY reccomend you to own official ones. this will be a bit more expensive but as you can see, official products can be much more reliable.
Hope i helped you !
Score 1
Add a comment
Just don't enable the "Enable 3G Button" which will drain out the battery life
Your charger might be broken so you might need to buy a new one
Add a comment
Add your answer
Calvin Millien will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 7,494
