Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
Dock,battery, charger,phone are okay but won't charge
Hi, this iPhone is extrimly confusing, I bought it on eBay as no signal not working and gives just the apple logo when switched to charger I fixed everything and I changed battery which was a new fully charged, time later coming back to charge it! It wouldn't and the battery stay remaining what it was charged at the time of plugging the charger! Any idea please?
I changed the charging port, the battery I cleaned the charging dock with teeth brush ... Did everything! The phone shows u that it is connected and in charging process but the battery would not charge at all
Score -1
Add a comment
Chosen Solution
Alaa, "phone shows u that it is connected and in charging " is usually caused by a failed/damaged charging coil. Check for any physical damage, or if you have the knowledge and tools, check for function. You want to start by checking 3 inductors. For that, of course, you need a multimeter, or at least an ohm meter, to check for continuity. I hate to refer to those as fuses, but they most certainly control part of the charging circuit. First one is reference designator L3, it is a FERR-120-OHM-1.5A inductor. L4, right below it , has the identical value. Next would be the charger inductor L28 2.2UH-1.8A-155MOHM. All of these are pretty much available at mouser. com or digikey.com. Check the Diode D604, located just above L28. Hope this helps, good luck.
Score 1
2 Comments:
thanks, after checking verry good these details i found the battery connector disconnected from the motherboard on one side so il try to weld it and il write u back, it might be helpfull for someone else
by
sounds good, let us know how it is going.
by
Add a comment
Try a different lead. Check it for water damage
3 Comments:
Do u mean that the connector on the mother board might be gone or blocked due to the be connection? Could that be a reason of not charging the battery?
Obviously I rubbed it with teeth brush as I also expected that but without using alcohol would that be enought?
by
allright sir i cleaned the connect on the board and still the same :) strainge really now im thinking it might be something in the charging route stopping electricity from reaching the battery, when i set it on DFU mode it stills on all the time but the lonley think not working is charge!!!
by
Try restore the device
by
Add a comment
Add your answer
Alaa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,870
