Repair guides for the MacBook.
3786 Questions View all
My screen is blinking
I have to push and pull the lcd until find a position to image appear.
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like you have damaged a cable... either the data display cable or the inverter cable.
That is not a hard DIY fix. Aquire the proper tools (any job is easier when you use the correct tool). Use the guide to remove the top case... inspect the cables for nicks/cuts, carefully moving the cable with a plastic/wooden tweezer or toothpick (to avoid shorting) can tell you which one is the problem... order a replacement an swap it out.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Guilherme Alves will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
