Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2399 Questions View all
Are the iPhone 4 and 4s LCD's the same?
I have taken apart several iphone 4's and a couple 4s's with cracked glass, but functioning LCD/Digitizer and have saved them all, I can't remember which ones are 4 and 4s, could someone tell me how to differentiate between the two? Also, I have just decided to try to experiment separating the LCD from the broken digitizer using a little heat and the iSesamo opening tool to pull the lcd off the broken glass, my question is, if I buy the glass specific for the 4 or 4s, will the lcd/digitizer i pulled off work correctly for either the 4 or 4s? Or should I try to figure out if the LCD was off a 4 or 4s FIRST and THEN buy the correct glass to reattach? I could end up saving some good money here per repair but I want to make sure I don't put the wrong lcd/digitizer on the wrong glass in the wrong phone...
Thanks
- Sean
Score -1
Add a comment
1 Answer
Most Helpful Answer
If you can get the glass of the digatizer then fair play til you.. The glass is the same in the 4 and 4/s it's the little brackets on the screen were you screw them into the mid frame are located different on the 4 and 4/s
Score 1
Add a comment
Add your answer
Prestige Computer Solutions will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 159
