How do I remove memory card stuck in disk drive?
sd memory card stuck in disk drive
If you're looking for the absolute proper way to remove it then you can follow the disassembly & replacement guide to remove the superdrive, once it's out you can tilt it so that the opening is facing downward and shake a bit to drop the SD card.
With that said, I've always had great success with pre-cut strips of packing tape. I would pull a chunk of 5-6 off the stack, peel the cover off of the top piece to form a sticky side and then slide it into the slot. Usually pushing it back, working to the left & right just a bit and pulling out will pull the SD card with it. If you don't have pre-cut packing tape (important because it's rigid) you might improvise with a 6" strip of poster board (to form a handle) with tape wrapped around one end sticky side out.
Hopefully this works for you!
Not a bad idea! Another would be to part the felt dust covers out of the way to give it enough rom to fall out using a folded over iTunes card cut in half.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 282
