Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Questions View all
Broke Battery Indicator Flex Cable. No MagSafe Light or Power.
The battery indicator connector flex cable broke at the point it rises off the case. I've ordered a new connector but it will arrive in a week. I'm worried, because the MagSafe charger light does not turn on too.
Is this normal?
Read another post where the poster had a green light but no power. I expected the board to fire up without the battery connected to the logic board but there is no light and no power. What next?
Update:
  • Installed the new indicator and cable. Only one screw could go back in but I found a workaround. When I pressed the power button, nothing happened.
  • Connected the AC power adapter. MagSafe got a faint green light but didn't start up.
  • Reset the SMC and restarted. Heard the chime and the keyboard lit up but had a blank black screen. No video!
  • Reset SMC again, same thing. No video. Reset SMC again (x3 now)
  • Restarted .... lo & behold everything works fine. Battery is 100%. I only have to change the clock which connecting to the wifi fixed.
  • Pressing the indicator button lights up the green lights.
Problem: The MagSafe light is still a faint green but I know it works. How do I fix it?
  1. Tried this YouTube: dim green light MacBook Pro 2011 unibody fix
  2. iFixit: Followed Simran's first post.
Score 1
1 Comment
Where I can get a battery indicator cable for my macbook pro 13 inch early 2011? thanks I broke mine while lifting up the logic board.
by
Add a comment
Chosen Solution
The problem turned out to be the Magsafe DC-in board.
The thinnest wire all alone on the side split. soldered it which fixed the problem.
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board Image
Product
$9.99
1 Comment:
Glad you fixed the problem :)
by
Add a comment
Most Helpful Answer
Install the new cable before panicking.
"For the thing which I greatly feared is come upon me, and that which I was afraid of is come unto me." Job 3:25
Score 1
1 Comment:
Do we really need scripture?
by
Add a comment
MacBook Pro does not turn on if the cable is broken?
Score 1
1 Comment:
by
Add a comment
Add your answer
atenyim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 5,229
