locking lever for screen digitizer
one of the plastic locking lever for the Screen Digitizer connectors broke. I cannot lock it back in place. how can i get a replacement part for this?
If you are replacing a broken digitizer then just use a piece of mylar from the old connector and cut a small strip the exact size and slide it in on top of the connector with the damaged clip. This will put the pressure on the connector the same as the clip and if done correctly will allow the new digitizer to work properly. I dont think you can replace just the little clip.
Hope this helps!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 229
