0
Score
Avatar
Luke Turner
Asked
What solder should I use on my iPod Touch
History
What solder should I use on my iPod Touch battery? What liquid flux should I use? What size tip should I have? What is the best inexpensive soldering iron?
Edited by: mayer ( )
Post Answer
Score
Avatar
Craig
2.1k
Answered
Accepted Answer
PermalinkHistory
I use 63/37 solder and kester 951 no clean flux. The extra flux will make a huge difference in the quality of the solder work when working with such small components. I use a tip that has a width of at least half as wide as the pad. The smaller the tip the slower the heat heat transfer rate. The tip size will determine the temperature you will need to solder. The smalller the tip the more heat you will need to melt the solder because of the slower transfer rate. It is better to have the contact last no longer than 2 secs [at 350C] with the pad to prevent damage to the circuit board. Make sure to clean the old solder off of the pad before resoldering. Adding the extra flux gives an extra bit of "wetability" it allows the solder to stick better and give flatter smoother solder joints as well as helps with bridging issues.
A little late and I already created a bridge. How do I get rid of the bridge that I created?
Luke Turner,
0
Score
Avatar
Jackintosh11
2.7k
Answered
PermalinkHistory
Use ifixit solder, and the ifixit soldering iron. you do not need flux, as the solder contains flux.
Lead-Free Solder
Soldering Station
Product Image
Soldering Station
Use to solder items. — 50+ available at 24.95 each.
Product Image
Lead-Free Solder
Lead Free Solder in a handy dispensing tube. — 50+ available at 4.95 each.
Does the soldering station come with a good tip for it?
Luke Turner,
Luke Turner,
@ Luke turner, use a desoldering wick with some flux on it, or even a solder sucker if you have enough room.
oldturkey03,
Add Your Answer
Today: 1
This Week: 15
This Month: 71
All Time: 1,105
