0
Score
Avatar
Ivan
Asked
Can I Upgrade my logic board?
History
I have a MacBook 2.0GHZ MA700*/A, and I would like to change my logic board to my other MacBook's 2.16Ghz(MB062*/A) one.
Will it be possible?
What other parts can be shared between this 2 models. Thank you.
Edited by: mayer ( )
Post Answer
Score
Avatar
rj713
70.9k
Answered
Accepted Answer
PermalinkHistory
Perhaps Ben can help us here. I looked at both models in Mactracker and found no difference except CPU speed. How ever this doesn't necessarily indicate compatibility for a swap. Why would you want to do this? Is there a problem with the newer unit? If that's the case you may want to remove the board from the donor unit and hold it near the other unit. What you would be looking for is do the cables match--are the connections the same--do the ports line up in the case? If everything checks out and you feel froggy go for it. To be on the safe side I would either wait for Bens answer or email him at ifixit for an answer. Ralph
MacBook Core 2 Duo
Answer to your second question it looks like most parts would work in the other unit. Ralph
rj713,
0
Score
Avatar
rab777hp
17.9k
Answered
PermalinkHistory
It's just not feasible to change your logic board. If you look at the cost alone, it's worth buying a whole new computer, with everything updated.
If you get past the cost, the work should be enough, unless you're a very experienced and talented technician with a lot of time on your hands it isn't a feasible repair.
Add Your Answer
Today: 0
This Week: 2
This Month: 6
All Time: 1,671
