Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
screen flashes a file with a? on a white screen
I have just replaced the hard drive on my white Macbook late 2007- have i done it wrong or do i need to re boot my laptop now i have installed it? It just flashes with a file with a ? on it on a white screen..
Score -1
Add a comment
1 Answer
Chosen Solution
Thats a good sign! you now know you put things back together correctly. But, the HD doesn't have any files on it at this point - Correct? You'll need to partition the drive & install the correct OS on the system using your OS-X CD/DVD that either came with your system or bought.
If you still have your old drive and it's working you could try migrating your files back onto this drive. To do this in your case you'll need a second Mac system to be the Master which will host your old HD via an external FireWire HD case iFixIt FW/USB kit or a USB HD case iFixIt USB kit which is only a connection kit Vs case and is much slower, but cheaper.
Once you get your old drive patched up with the needed hardware connect it to your friends Mac and check it out with Drive Utility. Don't do repairs! Unless you have a backup. Setup the connection FireWire (best), Ethernet or WiFi between your systems (review this Apple TN: Migration Assistant) Setting your system up in Target mode (slave) copy over your files from your old HD.
If all goes well you should have a booting MacBook with all of your files - Good Luck
Universal Drive Adapter Image
Product
$24.99
Add a comment
Add your answer
Amy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 157
