Can You use the front glass from an A1349 on an A1332?
Can I use the front glass from an iPhone model A1349 on an iPhone model number A1332?
Jeff Abramson, iPhone 4 A1349 (CDMA) and iPhone 4 A1332 (GSM) front display use the same connectors, but the placement of the mounting bracket tabs are different. It can be made to fit, if you cut the non-fitting tabs. You can also try to switch the frame from the display panel. I'd suggest that for a good repair, to use an original LCD.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,008
