Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
wlan greyed out, missing standoff screw upper right corner
Hi,
I just tried to find a solution for my problem on myself, but I wasn't able to google anything.
I recently bought an iPhone 4, which has the problem, that the wlan is greyed out. So I thought, it should only be the wifi antenna, so I bought a new one (including speaker, so not to screw anything up!) for 15€, tried to install it. Hasn't fixed the problem (even brought me a non working "enter pin" problem), so I removed it again.
If you do it right, you don't have to remove the whole logic board to get to the speaker, so when I tried to put it back together I noticed a missing screw.
http://guide-images.ifixit.net/igi/diPxJ...
On that picture its the upper right, orange circled one.
Below that one there SHOULD be follow screw:
http://guide-images.ifixit.net/igi/1nvkV...
That should be a 4.8 mm standoff screw.
If my WLan is greyed out, could those 2 missing screws be the reason for it?
If so, can I buy those anywhere? Like I only need the 4.8mm standoff screw, I could use the other orange circled screw (from the upper picture) if neccessary.
Thanks
Score -1
Add a comment
1 Answer
Chosen Solution
Yes. And check out the small contact mounted on the shield (http://www.ebay.com.au/itm/Internal-Meta... red arrow). This can fall off during reassembly.
You can buy a complete set of screws here: [linked product missing or disabled: IF182-026]
Add a comment
Add your answer
lordosiris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 840
