Score
Avatar
shatta
93
Asked
What is the normal temperature of a MacBook Pro
History
I don't know very well what is the normal temperature of a MacBook Pro working on a normal day.
I have installed iStatMenus and sometimes it records 68 degrees and sometimes 70 - 78 degrees of temperature. The fans are working fine. So I want to know if this is normal or what should be a normal temperature.
Can a hight temperature cause a serios damage on the logic board, processor, or the NVIDIA graphics card?
Some facts:
I have Snow Leopard
4Gb or RAM
Usually I use my computer in my office with air conditioner.
Thanks a lot my friends.
Post Answer
Score
Avatar
lemerise
16.2k
Answered
Accepted Answer
PermalinkHistory
It depends of the software you're running and if processor and the graphic card are doing intensive jobs or not. I think 68° to 78° is a safe temperature range in most cases. Just make sure that the MBP is well ventilated, don't let it overheat by running it on a bed but always use a flat surface to let the air flow under the case. Your logic board has an overheat protection via sensors and will shut down if the temperature reach a damaging level.
Long term overheating is hard on the logic board capacitors. They are rated for 2400 hours @ 105°C. If you run cooler they'll last longer...
http://news.thomasnet.com/fullstory/5681...
Edited by
Add Your Answer
