2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Ruined screw (5 Point Star Pentalobe screw)
my macbook 5 point screw is ruined and i cant get it out !!!!!!! What to do I do HELP ME
Score -1
Add a comment
Chosen Solution
For screws that I can't get to the head, I use these Precision Screw Extractor Set: Precision Screw Extractor Set
For screws where I can get to the edges of the screw, I use these Screw Extracting Pliers: Screw Extracting Pliers
For the screw you messed up, I use the correct tool, MacBook Pro and Air 5-Point Pentalobe Screwdriver
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
P5 Pentalobe Screwdriver Retina MacBook Pro and Air Image
Product
$5.99
Precision Screw Extractor Set Image
Product
$24.99
Screw Extracting Pliers Image
Product
$19.99
Score 1
Add a comment
Most Helpful Answer
Follow the answers from the tags on the right. You'll need access to an easy-out, a small drill or dremel tool. Every DIY job is easier when you use the proper tools.
If this answer was helpful please remember to mark it accepted.
Score 1
Add a comment
The easiest and cheapest way is to cut a very small piece of aluminium foil from your kitchen roll, and loosely put it onto the screw, then use a similar size normal flat blade screwdriver to unscrew the ruined one out.
Add a comment
Add your answer
razgill will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 9,462
