0
Score
dravmx
Asked
no power on, no light front led
How power on a MacBook without topcase?
Spanish:
no enciende mackbook, no prende led balck de enfrente, la bateria si carga, presiono boton de encendido peor no hace nada, ni luces ni ventladore ni nada.
Desconecte el topcase, hice "puente" sobre un integrado cerca de los fan header y estos encendieron, solamente los ventiladores no el mackbook.
0
Score
mayer
121.8k
Answered
Hook it up to an external monitor via the Mini DisplayPort.
The MacBook was hit just before the problem ... MacBookpro no power on, no harddrive run/sound, no fan header run, no leds power on, no display flash, no sound... that case would have to connect an external monitor, this is to check signal on the display or am I wrong? with a screwdriver pins together and the fans start spinning (only fans). Is there any way to do that, but would work to turn the logic board without Upper case? upper case may be the problem? (Power button), there is no way to test if upper case is working correctly? Thank You for help.
image of screwdrive on pin: [URL=http://img176.imagevenue.com/img.php?ima...][IMG]http://img176.imagevenue.com/loc195/th_2...[/IMG][/URL]
