A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Questions View all
Question Closed
Black screen, sometimes moving it let me see something
Hello
There is this Toshiba Satellite C660-1MG and the screen is black when I turn it on. From the border there is some white moving.
Moving the screen (opening and closing it again) one time on a million let me see something, but then it makes a little movement and freezes and goes white or black.
What can be broken and how can I fix it?
Add a comment
1 Answer
Most Helpful Answer
Most probably the connector that goes from the screen to the motherboard is broken try pushing the bottom of your screen a bit harder with your fingers to see if it flickers back to life if it does then u need to change the cable, its not that expensive usually.
Also try to connect an external monitor to see if u have video signal
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 315
