new battery not charging
Which side of the battery is up? red wire on left or right while soldering it to the board?
Ted, CT
Ted, CT
Ted Platt, I guess we are a bit confused ;-) Anyhow, if you look head-on at your logic board, with the connectors in the northern direction (up) then the positive is to the starboard (right) side and subsequently the negative is the port (left) side. R=Red=Right :-) Amazingly enough you have white wire, it should actually be black, but it happens. check with a multimeter to see if the red and white are positive and negative polarity. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 264
1 Comment
where did you get the battery from?
by _Z_
