0
Score
Avatar
Mark
Asked
SATA cable for SSD use in optical bay
History
So I bought a SATA bracket/mount for an SSD drive to replace my optical drive in my black 2006 MacBook. Once I removed the optical drive, I also removed the orange cable that attaches it to the motherboard. I figured it would attach to the SATA mount just like it did on the optical drive, but it has a different type of connection.
My question is, is there a different cable available that will allow me to connect my SATA drive in the optical bay (because the original orange one won't connect to a regular SATA connection)?
The part number of the problem cable is 821-0408-A
Edited by: David Hodson ( )
Please give us a link to the mount you bought.
mayer,
Thanks for the reply guys. I figured it out - I guess even though the primary HDD on the A1181 is SATA, the optical drive is a PATA connection - so basically I have the wrong enclosure type. So I did a little digging and found the proper enclosure that will work with the PATA style connection. True machead3, it was misleading from the description - I was lead to believe it would work with ALL MacBooks, but I think it's the proper one for unibody Macs and newer.
Mark,
Post Answer
0
Score
Avatar
machead3
21.3k
Answered
PermalinkHistory
I would talk with the kit vendor... if they knew you needed a different cable it should have been provide, or, made clear you need to purchase it.
If this answer is acceptable please remember to return and mark it.
Add Your Answer
