No charging after Battery replacement
Hello,
I have the following problem:
My iPhone can be used only with connected charger because the battery life was shortened to 5 minutes.
I suspected a defective Battery. I have ordered a new one, but unfortunately with the wrong APN. I could charge the iPhone only if it was turned off. Of course, I immediately ordered a new battery that has the correct APN.
After I installed the battery with the correct APN, I can not charge the battery. The plug icon but not the lighning symbol appears.
I've read that might have something to do with fuses. I checked the fuse. They are ok.
I hope you can help me.
Thank you = D
Sorry for bad english. My native language is german =P
1 Comment
Which fuses did you check and how did you check those?
by oldturkey03
