Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Why won't my iPhone connect to iTunes or my laptop?
The LCD screen won't work, and the phone will not show up in iTunes either. It makes a beep sound when I connect to my laptop, but nothing else happens. The battery doesn't charge and it won't charge using an adapter either. Please help.
Also I had to restore the phone yesterday, but it kept freezing on the update screen with the apple logo and loading bar.
Add a comment
1 Answer
Chosen Solution
DeanD, sounds like you have a lot going on with your iPod. The very first thing I would do, is to try a different cable and a different computer. Check the dock connector for any debris, corrosion, broken or bend pins. If that does not work, change the battery. replace the battery. Here is the guide for it. The battery is available right here. After that re-evaluate. If your display still shows no sign of life, check the ribbon connectors for any damage as well as corrosion. Clean the board with isopropyl alcohol, just to rule out any water damage. Use this guide to work on that. Once it is cleaned and you have a new battery, and still no screen, replace the LCD. The guide for that is here. Hope this helps, good luck.
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
iPhone 3GS Display Image
Guide
iPhone 3GS Display Replacement
Difficulty:
Difficult
30 minutes
Guide
iPhone 3GS Battery Replacement
Difficulty:
Moderate
20 - 30 minutes
iPhone Image
Guide
Repairing iPhone Liquid Damage
Difficulty:
Difficult
1 - 2 hours
Score 1
Add a comment
Add your answer
DeanD will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,883
