What is broken in the inverter when the backlight goes off
Hi,
I also have the backlight problem.
What is broken in the inverter when the backlight goes off after few minutes or sometimes hours? Howcome the light can be turned back on, by dimming all the way down and after that un-dimming one stripe only? I don't understand how that is possible.( temperature) I have ordered 2 inverters, from which one already was broken( display black all the time) and the other now is built in my macbook. Still the same problem. It cant be a loose contact, because it happens aswell, if i don't touch the computer at all. Also it doesn't occur if i wiggle around on all cables.
I red about a broken ccfl light bulb, but wouldnt a broken bulb colour the screen red-isch?
I also red about a small 3 pinn and 1mm big condensator or something which would have a "dry joint". Can that really be?( can search for link..)
Or Is the inverter i got send also broken? Meaning i should order a inverter again?
Thanx for your help
Jelmer
Jelmer, what are the last three digits of your serial number? This will help to identify your computer.
by oldturkey03
