After liquid spill screen dims on it's own. Need LCD expertise.
I had a cat/glass of water problem. It was not a lot of water but enough to get in on the left side of the keyboard around the escape key. I shut down. Dripped water out. Left propped upside down. Opened up the machine. Dabbed any remaining liquid and left open for over 24 hours in a hot room with a fan.
Everything is great with the exception of the display. It is dimming itself intermittently. Also occasionally showing the same symptoms as this link but not nearly as pronounced.
Any advice in terms of what workflow I should go through in finding the exact culprit? I'm assuming my possibilities are inverter cable, logic board, or possible lcd? I have another MBP around to troubleshoot with but I'm not sure how I would connect in order to test displays.
When I do a Shift-Control-Eject sleep and come out of it the display is generally better for a period of time. Eventually it starts dimming again, though.
