Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
90 Questions View all
Is there a way to tighten-up/more resistance the analog sticks?
I am trying to find a way to tighten-up or give more resistance to the analog sticks of the controller. In two areas, first in the amount of pressure that it takes when pushing it down .... i would like to make it stiffer/harder. Second, in the left to right movement in the analog stick, in order to reduce the sensitivity during game-play.
As it stands right now i just barely tap the stick, left or right and it travels way past the intended target, forcing another tap the other way to correct it ........... ant ideas?
Score 2
Add a comment
1 Answer
Chosen Solution
maxx, I just took a look at the analog controller and I do not see anything that would allow any adjustment. I would suggest to replace the stick with a set of new ones. They are relatively inexpensive and it only requires basic soldering skills to replace them. Hope this helps, good luck.
Score 2
Add a comment
Add your answer
maxx will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 59
All Time: 8,254
