PowerBook G4 Aluminum laptops with 17" displays. Released by Apple in 2003.
171 Questions View all
Why wont my laptop turn on, keeps trying to eject DVD.
I am having trouble rebooting my laptop (1.67Ghz,120HD,2Gb RAM,MacOs 10.4.9 or 10.4.11)
Have taken RAM out, swapped slots, done the PMU(?) reset, holdiing power key for 5-10 sec, ect. All with no luck.
Came back from holidays & it wouldnt get past the DVD check.
There is NO Vid display at all, not even a flicker.
the DVD seems be trying to eject maybe a DVD.
Score 1
1 Comment
OK there is no display but do you hear the hard drive booting the system ? If so connect an external monitor to the PB and tell us if you have a normal video.
by
Add a comment
Chosen Solution
Try starting up holding the option key down to see if there is a system disk in the drive. Try to eject the disk by starting up and holding down the mouse button.
Score 1
1 Comment:
There is no DVD in the laptop. It was taken out during the check on the PRAM batt.
by
Add a comment
The issue is it's failing the hardware check at boot-up.
You need to take disc out first, then try to boot.
At worst, replace the CD/DVD reader.
Score -2
1 Comment:
- read the question and responses before answering "There is no DVD in the laptop. It was taken out during the check on the PRAM batt.
harry allcock, "
by
Add a comment
Add your answer
harry allcock will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,309
