0
Score
Elvin
25
Asked
iPhone 4s greyed out wifi
hello, the wifi of my iphone 4s is not working, when ios 5.1.1 installed it worked 1 month without any problem, then it began to not working, after updating to 6.0.1 it's completely greyed out, i even cant switch it on, and weird part is that its working after put it freezer for 3-4 minutes, i'm preparing myself to repair it, i want to know which part should i replace? Wifi antena flex cable or schema top of iphone next to camera?
Score
Answered
Score
airshod
13
Answered
I opened the phone and identified the location of the wifi module and heated it up with a solder station heat gun, whilst protecting other areas of the phone with heat shields. This essentially reflowed the solder which connects the module to the main board. It fixed the problem for me. It is a similar problem that people experienced with the PS3 system, where the main CPU became unconnected due to poor solder joints.
My fix (posted earlier) worked for a couple of months then failed again. I now do the "hair drier down the headphone socket" method (phone face down on a non flammable surface, heat the headphone socket for about a minute). This tends to last between a few days or weeks. I will continue with this until the phone dies, then I'll go Android.
0
Score
Ken
13
Answered
Putting your device in a freezer really doesn't do anything other than cause some contraction of electrical components that may or may not fix a short. Problem with this is if it's temperature related, you'd have to have your phone froze all the time to work. The one thing you can do is take the back off and check that the antenna cable is connected all the way. But, even if it's not, your WiFi should not be grayed out. Have you tried to re-flash your phone on iTunes? Maybe try a complete factory restore and see if that helps.
I'm leaning towards Wee Anrul's answer that you have a faulty wifi chip.
Good luck!
Ken
0
Score
Answered
I note that you have updated to iOS 6, this maybe the reason.. Google it, there are many cases of iphone4S wifi problems after 'upgrade' to iOS6 including greyed out wifi. Its not a hardware issue, don't repair it. Wait for the iOS6.1 (apparently iOS 6.0.1 doesn't solve the issue).
Best of Luck,
Saq
Edit: This might help (some weird solutions) https://discussions.apple.com/thread/431...
Edited by: Muhammad Saqib ( )
0
Score
James
25
Answered
Does the device pick up a phone signal? If not, your problem could be related to your baseband. It controls your WiFi, Bluetooth and phone signal. What baseband are you on? Check by going to Settings>Genera
0
Score
Max GR
25
Answered
It's best for you to either
A: Should you have a good knowledge of fixing electronics:
Replace the iPhone's logic board, but before, make sure the Wi-Fi antennas are seated correctly.
B: You have no experience or are scared
Get a new (i)Phone or send it to Apple should your iPhone be less than a year old, they will most likely fix it for free, under their Hardware Warranty Policy.
0
Score
Leslie
Answered
I had the same thing happen last week to my 2 DAY old iPhone 4S, it was a hardware issue, I brought it to the Genius Bar and was given a new phone (after talking to Applecare). If you are not near a Genius Bar I'd call Apple, Applecare said I didn't qualify for tech support (as this phone replaced 2 previous phones that ALL had issues) but you can request a phone call if it's a hardware issue.
0
Score
Answered
0
Score
Hunzz
Answered
There is still one way that remains to fix it, when you were on IOS 5.1.1 and if you saved your S.H.S.H Blobs for IOS 5.1.1 with Tiny Umbrella, then as you are on IOS 6.0.1 you can downgrade without any errors on iTunes, after all, the problem of the greyed out wifi started with IOS 6.0.1 so why not downgrade back to IOS 5.1.1 which was basically the best OS update. Not only will this fix the "wifi greyed out" problem, but you will be able to downgrade back to IOS 5.1.1 whenever you want.
0
Score
Ryan
35
Answered
Buddy of mine called me with this same wifi issue on his 4S. I had no answers for him. He called me back about 30 minutes later and said that he did 4-5 hard resets in a row and it came back on. Seems like a iOS issue to me.
0
Score
Answered
Hey bud, this is a major IOS 6 bug that many people are going through. Apple will most likely be putting this problem #1 on their list because it has affected many iphone users. You are just going to have to be patient until IOS 6.1 comes out and the bug is fixed. If the bug is not fixed after IOS 6.1 is updated, then send your phone to Apple and they will most likely replace your phone or fix it. Apple has great customer service so I wouldn't be surprised if they replaced your phone for free. This issue is huge for Apple and they may lose many customers due to this issue. My advice is to just be patient until 6.1, but if that doesn't work, send your phone back and leave it in the hands of Apple's excellent customer service. Hope this helps.
-Alex
how can i send it? i looked website apple.com, in my country there is no choice to send it for repair or something, even i cant find an email adress of apple to complain about my problems, its ridiculous
Is there an apple store near you? because the can most likely take it there. what country do you live in?
i live in Azerbaijan, Baku, there is no official apple stores here, one more thing is that when its greyed out i cannot play games like GT Racing academy or Asphalt 7 Heat, i mean it influences apps crashing, and battery drains fast, but when i fix wifi temporarily putting it freezer im able to play games, battery performance is normal even if wifi is switchable but couldnt search any network, apps dont crash, i confused, in this situation, i think its software bug, but for some reason i think its hardware issue, confused
0
Score
leomel
Answered
0
Score
Josh
Answered
0
Score
Todd
Answered
I lost wifi while streaming music, and couldn't switch it back on. I tried everything written here. I talked with my carrier and made a genius bar appointment. Then it dawned on me....maybe it was the app that caused the problem. I deleted the app from the phone and did a hard reset. Whamooo! Wifi back up and running! I reinstalled the music app and everything is functioning as it was. Hope that helps and the freezer thing is a myth...
0
Score
singlebrow
13
Answered
Have you try this way?
Continuously reset network settings for 5 times.
Settings-General-Reset-Reset Network Settings-Reboot
See more from the article of "How to fix WiFi grayed out in iPhone 4S".
Edited by: singlebrown ( )
i drained battery by turning on flash light in camera settings, it got hot and turned off itself then i charged it and voila WIFI is back!!! but i dont know how long it will last :(
Elvin,
hi again, i opened my iphone 4s, and i saw on battery connector it has one missing screw, i ordered screw pack from ebay for 0.99$, if it solve my wifi issue i will tell you i hope it will help :(
Elvin,
Elvin, "its working after put it freezer for 3-4 minutes" points toward a fractured or cold solder joint, in your case possibly around the WiFI chip. You could try a reflow on that. If it would be software related, the freezer would not make any difference.
oldturkey03,
