0
Score
Asked
On/Off Button doesn't work! iPhone permanently on.
Hello -
I didn't see any guides tackling this particular issue: My on/off switch is not working. I'm ready to change carriers, and I need to turn my phone on/off a lot during jailbreak/unloc
When I apply pressure to it, it simply doesn't turn off. I'm thinking some lever is not making contact or something?
What is this system like and is it worth trying to fix it myself? or should I just get a new phone?
2
Score
Mark
37
Answered
For a temporary solution to an unresponsive on/off button, take and squeeze the phone between your thumb and index finger on the right or left side of the receiver (ear speaker), while you press the on/of button. For some reason or another the on/off button will work, while doing the squeeze.
Give it a try, worked for me.
2
Score
robert
25
Answered
This sounds silly, but mine had the same problem, and I blew very hard through the switch, just like a straw, and it started working fine. It probably dislodged some grime. Give it a try, nothing to loose!
Score
Answered
I have the same problem. I took my switch apart and will try to clean it (mine was dropped in water by previous owner).
If that don't work, a new cable harness (including the switch) costs £4.99 on eBay UK (seller phaetondvip88 - I've bougth from them before and are very satisfied). The harness is labeled as 'Apple iPhone 3G Head phone Audio Jack Flex Cable' in their shop...
But, I'm going to try clean it first... Just need to go out and buy some 'electrical cleaning solvent' or whatever it can be named :)
Score
Answered
I've now replaced both the battery and the button harness I mentioned, but still no go. I can't turn the darn thing off (!!) and I have no idea what can do this other than the button itself!!
I'll try Marks idea as soon as I'm sure that the battery is fully charged.
And if I unplugg it, it will start a reboot cycle as soon as it goes into sleep mode. That is, as long as I'm using it, it's just fine! But after a minute (I have a 1 minute delay until sleep) it will reboot so that the Apple logo is shown for a few seconds and then reboot again. It will not recover from this cycle until I plug it in to the computer. It's jailbroken and I've installed quite a lot of apps. I'm currently doing a complete reset and restore to original to se if that helps...
Score
Answered
Score
cyndi
13
Answered
Score
David James
147
Answered
You can turn the iPhone off in the settings..
0
Score
Answered
Success!!
I completely took it apart again. Removed the display assembly (but not separating this), mother board and sync connector. Cleaning everything by blowing clean, compressed air (from a aerosol can) in every nook and cranny and trying to get air in between the mother board and the RF sheilding from all directions, blowing everywhere on the back case and on and around the buttons (that where still in the case) and on all connectors (both on the mother board and on the flex cables).
Then assembled everything again, making 100% sure that all the connectors where correctly seated. Turn it back on and loo and behold! Everything works like a charm!! I can turn it on and off, I can enter DFU mode and it doesn't reboot as soon as I unplug the sync cable!! Dang, I'm a happy camper now!! :D
PS. Just in case this haden't worked, my next attemt would have been to spray/use some 'electronic cleaning solvent'.
0
Score
Rhiana
Answered
A temporary fix would be the gesture button.. Go to settings>genera
0
Score
wefixIT
Answered
My process:
- Remove on/off button and press the metal pad to see if it works (then the button has worn out) - the metal pad sits under the button itself
- If metal pad does not work, check that it is making a clicking noise -> remove pad and clean the contacts (sometimes they can be dirty)
- If that doesnt work you need to replace the flex ribbon cable which is challenging the first time but pretty easy when you figure out the tricks
0
Score
Answered
Dear sir:
1) The main switch can be faulty. However you must test it for open or faulty with DVOM and replace
You must try to clean the contacts with c.cleaner from sirty, corroded, tight the connector very well and clean it.
2) See the diagram attached, clean the main board from corrosion, debris, and bad contacts. clean it very well.
God bless you
Ernesto Cuadra
Managua, Nicaragua
-1
Score
Answered
