0
Score
Avatar
adhit
Asked
iPhone4 WONT CHARGED! no thunder bolt no other explenation
History
hi! i hv my iphone over a year. yesterday, when i wanted to charge it and i plugged it in, it just not charged. no thunder bolt symbol no other explanation such as "not supported charge device" or somthing like that, just nothing, like it isnt charged. i tried the hard restart (pushing the lock button and home button together for 8 secs) but it still wont charged when i plugged it in. then i leave it with the charger still plugged on my phone for about an hour then i checked it again, the battery was increasing! but just like 2 percent and still no thunderbolt symbol. so slow! must i change the battery ? what should i do to fix it ?
oh i forgot to tell you something.
once, my phone goes off cause the battery is 0%, n then it shows like this n it charged normaly until like a minute after my phone turned back on. when it turned on, its not charged anymore, like i said no thunder bolt but it actualy slow chraged. like realy slooow. spent a whole day for fullfilled it
Edited by: adhit ( )
facing the same problem now.. did u find ne solution? also an interesting way to fasten to charging is to switch off ur phone and charge it.. it boosts to 100% in the average time, if not faster!! i observed this cos when it gets switched off since it reaches 0, it charges to 4% quickly nd den starts.. after switching on it discharges wen used even if plugged.. this kept continuing.. wen is charged it by switching off, it got 100% charged in 3 hrs!!
Aditya,
Post Answer
Score
Avatar
Craig
2.1k
Answered
PermalinkHistory
Take a toothbrush with a little alcohol and swab out the charge port real good to clean the pins on the dock connector. I fix a lot of them like this.
hi, thx for the answer... i did what u told but it still didnt work.. is the iphone u fixed charged in the slow duration and without a thunder bolt symbol? mine is like take the whole day to full fill the battery..
adhit,
0
Score
Avatar
gizmo4sal3
1.6k
Answered
PermalinkHistory
You could try to unplug the battery and re seat the connector.
Have you tried a different charger to ensure its not a problem with that particular cord or adapter?
Also, look in the bottom of the dock connector and make sure there isn't any pocket lint or dirt lodged into it. This does happen. Make sure also there are no bent pins or damage to the connector itself.
Hope this helps
Update
it could be the battery as well. If you can order one in and try it that may very well resolve the issue entirely. Now that we know everything is squeaky clean! :)
Edited by: gizmo4sal3 ( )
thanks for the respond, i did that, and also i try 3 diffrent wall charger n it still didnt work. :( i tried plug it in into my laptop, n also no respond. i already cleaned the dock, n im so sure theres no dirt anymore. the funny thing is it is charged but theres no thunder bolt symbol n also so freakin sloooooow! i left my phone with the charger pluged in for 1 day n it filled like about 95% from 0%. i think somethingwrong inside the phone or the battery.
adhit,
0
Score
Avatar
oldturkey03
144.1k
Answered
PermalinkHistory
adhit, just like Craig suggested, start by cleaning the dock connector properly, replace the battery, make sure the battery connectors are properly attached to the board. Worst case scenario, you have issues with the power management IC. check this video for a reflow and the image to see if the jumpers might help you out. Place jumpers across the fuses
i did what craig told to me.. and im sure the dock and the pin is now clear. so i have to change the battery? if so, that its the power IC problem. i cant solve that myself. and im sorry i dont understand with this jumper.. so maybe the best thing i can do is maybe i have to replace the battery ? so heres the funny thing,it does charged but it takes so slooooow like a whole day until it, well.. not ompletely full :/ thanks anyway for the respond :)
adhit,
Yes, i would suggest to change the battery. It is possible that this is the reason for the slow charging. If it is not the battery, take a look at the Power Management IC
oldturkey03,
oh i forgot to tell you something. once, my phone goes off cause the battery is 0% is, n then it shows like this n it charged normaly until like a minute after my phone turned back on. when it turned on, its not charged anymore, like i said no thunder bolt but it actualy slow chraged. like realy slooow. spent a whole day for fullfilled it
adhit,
0
Score
Avatar
Vitor Mansur
Answered
PermalinkHistory
Hi,
I have the exact same issue...
does something actually solved your problem?
thanks
0
Score
Avatar
Kelly Asai
Answered
PermalinkHistory
I have the same problem on my Iphone4. Slowwwww charge wit no thunderbolt and the battery icon. takes a full day to charge it. But it charges faster in Off mode. Help me
0
Score
Avatar
Vitor Mansur
Answered
PermalinkHistory
i've changed the charging port connector of my phone and it solved the problem...
iPhone 4 Dock Connector Replacement
good luck
Add Your Answer
Today: 5
This Week: 12
This Month: 65
All Time: 2,464
