Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Only top of screen is visible, rest is white/negative
After replacing the battery and re-assembling my ipod touch 4th gen, only the top of the screen (where the battery status indicator is) is visible, the rest of the screen is bright white/negative colored but i can still read the text. All other functions are good. I tried to disassemble the ipod twice but the screen remains the same. Is this the LCD or something else?
Thanks in advance!
Greets.
Add a comment
Most Helpful Answer
Its the lcd.
Score 1
Add a comment
I have an Ipod touch in my shop right now with the same issue. I pressed the home button fairly hard 3-5 times fast and the colors shifted back, not sure if this will salvage it but worth a shot.
1 Comment:
Thanks for the answers! I tried to press the home button as you said but this didn't solve my problem, I ordered a new LCD yesterday so I hope this helps
by
Add a comment
yes, you can put the "invert colors" function for better readability on the triple home button click. but then the display would be completely inverted. since only a part of your screen is inverted it is definitely a broken lcd.
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 9
All Time: 431
