2
Score
carlb48
25
Asked
4
Score
Andrew Bookholt
191.3k
Answered
It is soldered to the board, as seen in the picture on step 12. Also, the battery uses a thin ribbon cable whose solder points are essentially holes through the ribbon cable itself, so it is difficult to solder but definitely possible (I've done it before).
Edited by: Andrew Bookholt ( )
0
Score
Richie
Answered
0
Score
bal3is
Answered
after removing the Battery ribbon, will you see three lines with solder on them? because i think i overheated it and removed a metal plate.
0
Score
Paul
11
Answered
I just joined this forum and did this myself on my 2nd gen iPod touch and it is my believe that one of the three battery connection or solder points, specifically the middle one, does not have a solder plate or line underneath it like the other two, which were very easy to solder back on, but the middle one gave me the impression I overheated and removed it, but there are no traces of a plate in the middle, not even at the old battery's middle connection point.
0
Score
Answered
how to check the battery
marcooliveira30
0
Score
donell
Answered
0
Score
Answered
The three points all have metal connection which need solder!! if you over heat the board its hard but if you roll the solder directly below to the gold point you will return the connection!! you can also slip the lifted pad back in place and solder the two outside points down then solder the middle one last and this will actually hold it down and keep connection as well.
Edited by: oldturkey03 ( )
