Why isn't my iPod turning on?
i left my i pod touch out side one summer night and it wont turn on wat do i do
hannah, first make sure that it is fully charged. Then try to restart it by:"
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
Press and hold the Sleep/Wake button until the Apple logo appears." If that does not work, try a hard reset. Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo should appear on the black background. Once the logo appears, you are done. Hope this helps, good luck.
What if my home button doesn't work?
I tried everything to turn my iPod on. I pressed the on button for 10 minutes. Didn't work. I tried the home button. Didn't work. And I also tried to do both the home and on button. It still didn't work! What happened to it? It's fully charged and everything. What should I do? (I know this is more of a question than a comment, but this is all I can do right now.) If anyone has any advice for me, I would greatly appreciate it. Thank you!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,185
