0
Score
Avatar
Ryan Busboom
Asked
Ethernet Connection Not Working When Cable is Plugged In
History
This question is archived. No new answers are allowed, and only the question's owner may edit it.
My WIFI connection works just fine with my computer. I am not able to connect to the internet if I plug in a ethernet and disable the WIFI. I have been told by the Apple store that the port is not working correctly. I would like to find out how I can replace this port/connection.
Edited by: iRobot ( )
Hi, how did u come to the conclusion that the ethernet port is faulty? Is it loose. U can disassemble the mac and see what part u need. I would recommend to first rule out that this not a software issue and a hardware issue. Also take it to a professional for the soldering bit. Write back on what u did. Good luck.
John Savio,
There are a few possible issues here that you should checkout before assuming it's the iMac's circuitry. Can you give us an idea on what your connecting the iMac to? Does it have a link light that you can tell what the connection is doing? What does this device connect to and how does your WiFi connection connect (wired side).
Dan,
Post Answer
Add Your Answer
