0
Score
Cliff
Asked
I took the screen off my iPod and it wont power on anymore, quick fix?
This question is archived. No new answers are allowed, and only the question's owner may edit it.
Okay so this was the first iPod i have taken apart, and when I say that I only took off the screen because I have no tools small enough to remove the screws. I had originally taken off the screen to try and fix the home button but with no tools that obviously didn't work. so I began putting it back together and once i finally got the digitizer reconnected I got nothing at all. It wont turn on, charge from the wall, dock, computer, or car, and the computer and dock don't even know that its there. Now I have to admit I didn't have the cleanest of screen removals, the wifi antenna stayed glued to the top and became separated from the bottom where it is meant to be, I did later separate it from the top, however it is in one piece still with no rips, tears, or cracks. the other thing that went wrong from what I can see is the grounding spring got a little mangled, but it still very much contacts the original point on the upper glass part of the iPod. I also kept the black tape wire very much intact, although I'm not sure what it's for i feel like that's what gives the power to the screen. About the broken home button, I would like to fix it without replacing it even though I do realize that's probably not possible any help on that would be appreciated, note I have tried the rubbing alcohol method that seems to be pretty common.
Edited by: iRobot ( ) , Cliff ( )
