0
Score
Asked
hard drive speed and identity of the iMac
i want to puchase a replacement drive for my puter....your discription of a replacement drive shows a picture with the drive exposed....is this how it really looks out of the box..or did you remove the cover for viewing?
in the description it does not indicate the drive speed...what is the drive speed for the 1tb seagate drive listed for 129.95
are there MB identity number for my mac? apple identifies with MB878LL for my imac 24 2.4 mid 2007
0
Score
Dan
7.8k
Answered
Did you review the iFixIt guide on what it will take to replace your current hard drive HD replacement guide? You will need tools and you do need to be careful as you can break or damage things if your not.
Steps 12 ~ 17 shows the hard drive currently in your system, your hard drive may look different.
Maybe you might find an external hard drive a better option if you have not taken a computer apart before. I do recommend using a 1GB or 2GB firewire 800 external drive as a good option here.
If you do decide to give it a go, I do recommend getting an external firewire 800 case to house your old drive when your finished. But before you start put your new drive in this case and use Apples Migration Assistant to copy your OS and all of your files to the new drive and even check it out by setting in the prefs this drive as the startup disk. Restart your system and see if it's the first listed drive on your desktop if it is your all set to swap the drives. After you finish put your old drive in the external case as a backup.
