0
Score
Asked
Reversed brightness keys, and screen is too dim. What could it be?
This question is archived. No new answers are allowed, and only the question's owner may edit it.
I have a weird problem with a Toshibe Satellite M105 S3031 laptop, the brightness buttons have been reversed: the combination that should bring the brightness up (Fn + F7) decreases the brightness one step every 2 key presses, and the one that should lower it (Fn + F6) incresases it one step every 2 key presses.
The real problem (since I could tolerate the keys working backwards) is that the screen, at the highest achievable brightness is too dim for using in a well lit room.
The problem seems to be hardware related, since it fails this way even at system POST.
There are few times when everything works ok (with a brighter screen), and stay that way until the system is restarted.
I´ve already trying flashing the latest bios available, but nothing changed.
Does anyone have any idea how could I fix this?
EDIT: typos
Edited by: iRobot ( ) , sancheztavo ( )
Have you tried an external monitor to make sure that your GPU is okay? right now it sounds like your backlight is out. That could be cause by a bad inverter, CCFL, cable or bad LCD.
oldturkey03,
The GPU is OK, s there anything else I could do to get a better diagnostic?
sancheztavo,
How did you test the GPU? Did you check with an external monitor?
oldturkey03,
