0
Score
Avatar
Donald
Asked
WD 2TB HD fit in a Mac mini 2012
History
HELP...
Will the new WD 2TB HD fit in the new Mac mini (as a 1st or 2nd HD)?
Thank you
Post Answer
Score
Avatar
rj713
39.1k
Answered
PermalinkHistory
Don if the 2 TB is what you need you can install two 1 TB drives with this kit.
http://eshop.macsales.com/item/OWC/DIYIM...
Edited by: rj713 ( )
0
Score
Avatar
Dan
6.4k
Answered
PermalinkHistory
Don - Don't know of a WD 2TB drive, can you supply a link about it.
What I can tell you is you need to use a 2.5" drive and you do have some head room issues (depending on the model), As your asking about the new '12 model iFixIt or anyone else has not opened one up yet so we just don't know whats inside for space and connections.
If Apple followed the last version two 9.5mm hight drives will fit. Wester Digital and heres the iFixIt guide on replacing the '11 model iFixIt Guide '11 model
Edited by: Dan ( )
0
Score
Avatar
Donald
Answered
PermalinkHistory
Don - Its too high (15 mm) Sorry guy ;-{ Heres the spec sheet http://wdc.com/global/products/specs/?dr...
Dan,
0
Score
Avatar
99fordracing
Answered
PermalinkHistory
I Tried that 2tb drive it in my 2012 Mac mini. It is to high will not fit
0
Score
Avatar
Hebs
Answered
PermalinkHistory
It will fit. I have it in my 2011 Mac Mini next to an OCZ 256GB SSD.
The only way to get them to both fit is to remove the back plastic case/cover from the SSD and don't fix/screw the 2TB drive to the mounting frame.
Just don't ship the system or move it about to much as your likely to damage something as you have nothing anchored.
Dan,
Agreed, but it is wedged in tight and I added foam/rubber pads to fill the 1.5mm gap. Should help limit/stop movement. Ideally someone should make an HD caddy/frame with the HD screw mount holes in different positions.
Hebs,
Add Your Answer
