0
Score
Bruno E
Asked
After antenna replacement 3G service gone.
This question is archived. No new answers are allowed, and only the question's owner may edit it.
Hi there. I'm using my IPhone in Europe. While changing the homebutton, I broke two of the clips of the antenna. The consequence was that the signal was very weak.
So I ordered an antenna for GSM here at fixit and I replaced the installed and broken antenna with the new one. Now the carrier-signal is found perfectly and I can use the internet with EDGE. But 3G is gone? It's put "on" in the IPhone-Settings and I already tried the "network reset". Everything works fine only 3G is gone.
Has anyone already had this problem? I checked twice that I ordered the GSM antenna, not the CDMA one.
Best regards - Bruno
Problem solved. That was really funny. I opened the IPhone again (running) and removed the antenna-plug from the motherboard. Then the carrier-signal was gone. After this I reconnected the antenna cable and there was full 3G service. Strange. Conclusion: Make sure the antenna cable is deeply attached to the small round connecter on the mainboard. Otherweise it might have enough contact for EDGE, but not for 3G.
Bruno E,
