0
Score
Avatar
Pedro
Asked
How to configure ssd as a first drive
History
Hi, I´m going to install a SSD in my Imac 24 inch 9,1 ( early 2009 ) replacing optical unit and use the HDD as a second unit.
How I Should format SSD to install mountain lion for use it as a system unit?? Should I put TRIM enabled??
Will lost speed if I will install SSD replacing Opitcal unit? or Its better to install SSD in HDD place and keep optical unit?
Thanks in advance and sorry for my bad english.
Post Answer
0
Score
Avatar
rj713
39.1k
Answered
PermalinkHistory
Hi, Here is a link to a previous answer to your question that may help you. Good luck.
http://www.ifixit.com/Answers/View/85924...
Thanks, and what about configuration to use SSD as a system unit??
Pedro,
Once you have the SSD installed and install a working OS on it, all you need to do is go into the startup pref settings and select it as the boot volume (system), and restart.
Dan,
Add Your Answer
