0
Score
Avatar
Schoonhoven
Asked
Replaced my back cover & front assembly, phone won't start. What now?
History
I replaced my back cover because it had a crack in it. I followed all the instructions on this site to replace it. While removing the battery it bend a little bit at the top. I checked the voltage and it gave me 2.8V. I put everything back together (with the new back cover). I also replaced the whole front assembly because my LCD screen was broken and didn't want to struggle with replacing the lcd screen. Now everything is put together and nothing is happening. I don't know what to do anymore. Tried a couple of stuff, still nothing. Please can i have some advice on this problem?
Edited by: Schoonhoven ( )
Post Answer
0
Score
Avatar
John Savio
663
Answered
PermalinkHistory
Hi, first thing I would recommend is put the phone on charge as I think the battery voltage should be 3.7v. But before doing this I would again recommend is to remove the board high enough so that the battery terminals are not touching it, so in effect if the phone is "on" u "off" it. Reassemble the phone and put it on charge. After about 15 mins if you hear a beep then all should be ok. Dont by mistake press the power button when assembling the front screen. Write back with more details on how it went. Good luck.
Thanks for ur reaction. I tried it and still nothing. So i put back my old lcd screen and it started !! I removed the new lcd from the assembly put it in the old assembly and it started only now my screen is flikkering white and green an blue and everything. What is the problem now??
Schoonhoven,
Add Your Answer
