0
Score
Asked
automatiacally restart when OS is installing
This question is archived. No new answers are allowed, and only the question's owner may edit it.
My laptop is automatic restart when i am using. so i decide to format c drive only. and when i am installing window 7 and any other OS then my lapi again restart .. so what should i do... please help me
The restart could be caused by overheating or failing power supply. Try to run your laptop with a LC Linux CD. You do not have to install those. See if it shuts down with that. If it does, time to disassemble your laptop and take a look at the fan, CPU etc. I would use Puppy Linux since you can run it either from CD or a USB drive.
oldturkey03,
Thanks for your Suggestion.... i check all the power supply and also remove the dust from the fan and again try to install the OS but problem is still there.. and i start my laptop and open the BIOS setting to check is there any hardware failure... so i m start laptop for more then 1 hr but it's not restart a single time in BIOS mode .....
rakesh jain,
can it possible laptop CD Driver has some problem... actually i check with another CD.. the problem is same. please give me a solution as soon as possible thanks
rakesh jain,
TRy to run the computer from a Live CD, Something you do not have to install, like PuppyLinux. Set your BIOS to boot from CD and see if it stays runing or if it reboots as well.
oldturkey03,
