0
Score
Avatar
fisher1
Asked
iPhone has no service after screen replacement
History
recently I have been repairing a few iphone 4's and have came across this problem twice now.
after replacing a screen the phone loses all service
the blue part that is often damaged seems to be fine but still get no service. could it be a problem with the gold metal but at the top of the phone? how should this sit?
Post Answer
Score
Avatar
sarah
79
Answered
PermalinkHistory
Do you have the new IOS6 update???
If so, just use another phone to call your mobile. Not sure why this works but i haved now repaired 6 4s with this new update and after i repaired them they all had the searching come up, now i just call the number and it kinda like resets the reception.
hope this helps
Score
Avatar
alex
417
Answered
PermalinkHistory
Set the date and time manually. If you take out the battery on the iPhone (iOS 6.xx) the date will be 1970.. :p
When you have set the date and time, remove the sim card and put it back in.. This should work :)
(you kan also connect the phone to the WiFi to automatically set date and time. Do the same with the sim card, when the time is right :) )
Score
Avatar
Craig
687
Answered
PermalinkHistory
I do not understand why people assume a problem is software when it has just had a hardware repair done on it. I would be willing to bet the antenna is unplugged or needs reseating.
0
Score
Avatar
Davide
Answered
PermalinkHistory
It's an IOS6 issue. Make a full restore and you'll get the signal back after initializing it!
Hope its help
did this and still the same problem
fisher1,
0
Score
Avatar
Joe
11
Answered
PermalinkHistory
I curious as to the positioning of this gold metal piece also as I am having similar issues. I have a signal but only in strog areas and 3g and wifi are bouncing on and off effecting the signal. Im curious as i sat this piece in as i believe is correct but cant get a pic of it anywhere. They say there could be some grease on the attenna cable so might try cleaning this with alchol
0
Score
Avatar
sarah
79
Answered
PermalinkHistory
There is about 7 different trouble shooting you can do.
Call the phone
Call out from the phone
set date/time
take your sim card out put someone eleses in it then put your one back in
reset phone
leave the phone alone for 10min dont touch it
Thank god for the IOS 6.0.1 that has just came out, hopfully that has fixed the bug
0
Score
Avatar
knud Knudsen
Answered
PermalinkHistory
I also had "no service" after repairing the screen on an IPhone 4S with IOS 6.01. As stated the date and time will be 1970... After hours of headache I decided to try setting the time manually as mentioned by Alex, power off/on the phone and enter the Sim pin code again. I had low expectations, but it actually solved the problem. Afterwards, you can switch back to automatic date and time again.
Add Your Answer
