Score
Avatar
MASTA KAHUNA
61
Asked
Intermittent Gsm reception on iPhone 4
History
title corrected ,
the issue is
error -1 in itunes
after applied ios and fixed and cleaned the board,the issue is interminent signal loss, it has been cleaned with isporopyl and the blue inductor is in place ,the gold hook is at the top ,btry swapped ,what else can i do ?
http://i49.tinypic.com/20u9yy9.jpg
this is the only image ih have ,should i remove the blue inductor ?
Edited by: MASTA KAHUNA ( )
After water damage it all depends on what you do to the phone after it gets wet determines how bad it is. Cause the bottom line here with water damage is the the water itself does not cause damage, The electricity jumping across the water creating shorts is what breaks electronics. redo your post with proper pictures and a full explanation of what happened and what was done so far. Please don't post a link on the title.
qpunk,
have you got any idea ?
MASTA KAHUNA,
guess not.................................
MASTA KAHUNA,
If you follow what FF90 is requesting, you may actually get some more help.
oldturkey03,
i still see no help here! how can IBE MORE CLEARER? the iphone is now DRY! no water in it.....it was cleaned with alcohol ,it works accept the signal is interminent ! SO THE BLUE INDUCTOR IS IN PLACE! and i suspect either the skyworks chip or the blue conductor !!!can you please help in diagnose the issue ?
MASTA KAHUNA,
Show 1 more comment
Post Answer
0
Score
Avatar
Puru
603
Answered
PermalinkHistory
Clean the Antenna Port both male and female. You may also use Magnifying Glass while cleaning to give a deeper clean. Any residential liquid portion may behave to signal collapse or electric current interpolation tension resulting massive signal malfunction. It may resolve your issue I believe.
0
Score
Avatar
Will Preston
49
Answered
PermalinkHistory
on the bottom of the iphone is the speaker assembly. Attached to that are 4 prongs that touch a metal plate when it slides in. Make sure those prongs are connected to that metal. If they are not fold up a piece of paper and slip in in between the gap from the speaker to the prong so the metal is touching that plate. BE CAREFUL with those prongs they are extremely fragile.
Add Your Answer
