0
Score
MASTA KAHUNA
61
Asked
Intermittent reception iPhone 4 board repair
This question is archived. No new answers are allowed, and only the question's owner may edit it.
Hi guys
after water damage bb issue fix of error (-1) in itunes
the issue is Intermittent gsm recepetion drops
boards seems dry sim contcs seem pretty ok i think,and also the blue inductor is in place ,the antenna cable is pinned right
what is else to check ,?a n y i d e a s ?
Edited by: iRobot ( ) , MASTA KAHUNA ( )
did you ever clean the phone after the water damage? It is easily possible that you have failure due to corrosion. Did you change the battery as well?
oldturkey03,
hello oldturky!at first i had also low wifi signal -but i fixed it implementing the small piece of metal on the metal bracket covering the eartpiece .>>>> yes i have cleaned it completely with alcohol ,and have also swappped with good known btry! here is the picture ,http://i49.tinypic.com/20u9yy9.jpg can it be the docking charging port which that makes it lose signal? though i believe its the board!!but there must be a fix to this!!! any idea ? of what else i shoul do ?
MASTA KAHUNA,
p.s the flash also doesnt work (with a good known swapped camera)can it be that the board have still corosion in it ? for how long should i soak the whole board in it alcohol ? and the rice drying is fine ? ,the blue inductor seems to be fine (its in its place-so i jst recon) ,i also cleaned metal to metal with material such as cleaning windows
MASTA KAHUNA,
hey guys no one is out there with the knowlsedge of reboll or jumpers? no one can help me ?
MASTA KAHUNA,
