0
Score
Avatar
Kyle
Asked
Solid Red Screen after digitizer replacment
History
After a digitizer replacement the LCD is solid red see photo. I tried another LCD same issue, so its clearly something on the board/connector but it was not like this before the repair.
Any help is appreciated.
https://www.dropbox.com/s/748sx9qb1gtp7o...
Edited by: iRobot ( )
Post Answer
0
Score
Avatar
Brad
151
Answered
PermalinkHistory
You most likely picked up a defective LCD. You can always try a hard reset, if it doesn't change anything this is probably the issue.
The LCD was fine before the glass replacement. I tried a known good LCD and the iPad had the same issue. I still would like to know what causes this
Kyle,
0
Score
Avatar
V900
Answered
PermalinkHistory
It's some sort of loose cable. I've had the exact same thing happen to me after my ipad2 experienced a slight drop on the floor.
(You can still see things on the screen, but the red pattern is still always sort of there in the background, right?)
Anyways, I read about this happening to other people online (try googling it) and the solution suggested one place, was to punch the back of the iPad.
I turned it around, gave it a good solid couple of whacks, and it fixed the problem, works fine now.
Add Your Answer
