0
Score
Avatar
Mittchel
21
Asked
Please help fast: Keeps saying searching
History
Hello everyone,
I tried to replace my front glass, but now I've got 2 problems. My first problem is when I boot it keeps saying 'searching' for some reason. It doesn't ask my pincode for my sim card.
My second problem is.. I broke the little wifi antenna the thing where you pop it in came from the motherboard.. what can I do?
It's not my iphone please help me quick :o
the male connector came of the circuited board? That could most certainly explain why it is searching
oldturkey03,
Isn't that for the wifi? so I mean the small thing which is under this thing: http://images.anandtech.com/doci/4971/4S... How can I fix it?
Mittchel,
It'll help if you post an image of the actual broken part, including the board.
oldturkey03,
You won't see anything on the picture. Though I can explain. On the 4S you've the wifi antenna which is under the screw on this picture: http://images.anandtech.com/doci/4971/4S... And you click the antenna ONTO the motherboard. Well, the thing where it needs to be clicked in came off the motherboard and is still attached to the antenna. But that doesn't make any sense why its keep saying searching and doesn't popup my pincode screen..
Mittchel,
Does anyone know what causes this problem?
Mittchel,
Post Answer
3
Score
Avatar
Christophe De Wolf
127
Answered
PermalinkHistory
I think the searching thing is a bug in iOS 6 !
Try to set the correct date/hour before insterting the SIM card !
I tried the date/time-thing and it worked. Amazing :)
Marcus,
The date/time-thing worked, thanks Christophe!
Tobias H,
Score
Avatar
iwillfix
4.7k
Answered
PermalinkHistory
i don't think the wifi antenna makes the phone say searching.
is the iphone running iOS 6?
maybe there is something wrong with the software.
as soon as you take out the battery you'll get the searching thing.
also doesn't recognize any sim.
connect to itunes and restore
Indeed, it doesn't ask for my pincode at all.. And it indeed runs 6.0. This all happened after I took the phone apart. I'm going to try a restore, sadly :p
Mittchel,
Worked like a charm! Though, I have to solder the WiFi connection back to the motherboard and hopefully my WiFi comes back.
Mittchel,
How can I accept your answer? lol
Mittchel,
No idea how you can accept my answer, but if think i found a solution. Need more phones to test en be sure. Remove the simlock code (with another phone..) Worked on 2 phones so far
iwillfix,
Score
Avatar
sarah
115
Answered
PermalinkHistory
Do you have the new IOS6 update???
If so, just use another phone to call your mobile. Not sure why this works but i haved now repaired 6 4s with this new update and after i repaired them they all had the searching come up, now i just call the number and it kinda like resets the reception.
other words just call your mobile from a different phone
hope this helps
Worked for me 2!
iwillfix,
0
Score
Avatar
Puru
1.1k
Answered
PermalinkHistory
First of all, Reseat the upper right antenna of your iPhone which seems like pulled off little bit or has not been seated properly. Solder the antenna that came off carefully. It should work. If it solved your issue, please mark the answer as Accepted.
0
Score
Avatar
Marcus
149
Answered
PermalinkHistory
I too have this issue. I don't have any possibility to connect it to iTunes at the moment.
Can anyone else confirm that it helps to do a reset in iTunes?
0
Score
Avatar
124electronics
Answered
PermalinkHistory
salam...
I am an small time independent technician.
I am not so sure about your battery problem but double check by replacing your battery or battery connector. whereas about the searching part I have been having the same problem with after replacing display assemblies for some of my customers and most of the iphones were repaired and fixed by restoring only maybe its a bug or an an apple hole for all of us to fall in or its just me.
The date and time adjustment as well as calling myself did not work for me.
Malik.
For the date/time thing Do not insert sim Connect to wifi Go to date/time settings Turn off automatic Set to x/x/2012 Turn on automatic Check if it corrected date to today Insert sim If this doesn't work. Probably not ios 6 bug...
iwillfix,
0
Score
Avatar
daniel
Answered
PermalinkHistory
mine has searching on the left top corner and does not read the service i repaired the screen and the wifi is sweet and is not 6.0 but 4s
Ios 6.0 is a software version for the 3gs, 4, 4s and iphone 5
iwillfix,
0
Score
Avatar
Super Adik
Answered
PermalinkHistory
its just simple guys !!!!! i m having this problem after replacing the midle plate .....just turn off your device n than open the backcase - the battery and the last 1 is unplug the celluler antena then plug it again (this work for me after i tried all the sollution above )
sorry for my bad english at typing just share here
0
Score
Avatar
Mark Kingsley
Answered
PermalinkHistory
I recently changed the LCD on my iphone 4S. I took a lot of care when doing this and the logic board seems to be in great condition with everything else working, inlcluding the speakers, touch screen and wifi. But I can not get any signal from the sim card even though the iphone can register the sim card details, and says no sim card installed when I take it out.
I have tried a lot of the solutions people have suggested on here. I have cleaned all the metal contacts with alcohol, made sure the connectors are properly connected (well atleast I think they are) and even bought a new antenna, a new chassis, but nothing seems to have worked.
I have realised the emergency call didnt work, so would that suggest it is an antenna issue??
Any help at this point would be really greatful.
Regards
Mark
0
Score
Avatar
Athreyu
Answered
PermalinkHistory
That *@!#!*$ date setting keep my phone searching after update ios 6.1
Thnx everyone...
0
Score
Avatar
ablokeonaduke
Answered
PermalinkHistory
I would also like to thank Chris for his answer, but can't figure how to add under his post! My experience was a little different and may be helpful to others. The iPhone 4S of a friend needed the screen replacing and it is OS5, but the date fix worked. I have never done this before or even owned an iPhone. I followed the guide here
iPhone 4S Display Assembly Replacement
which is complete except it doesn't mention the front camera surround (a clear plastic ring with a bit needs to be prised off the old screen and put back in the phone body and the new screen put on from top so the surround thing doesn't fall out.
I am very meticulous and felt I did a good job, but got a continuous Searching. Telstra couldn't fix it! They did the sleep reboot and other stuff and wanted to sell a new phone! Going into settings general date&time, turning it to manual, setting it to current date & time, ejecting the sim card and reinserting it, turning airoplane mode off then on got it sorted. The last step was probably only needed to recheck as where I fixed the phone there wasn't good enough signal to pick up but going outside then turning aeroplane on & off saw it sorted.
I did as a "by the way" also connect to my wireless system before doing the above, this was just to see if that worked or not, but I was connected to wireless throughout the above procedure, doubt it is important but stating for completeness.
The unusual aspect to the above is this was an OS5 phone whereas others say it is an OS6 issue, it seems it is really a bug that has been carried on from earlier!
Add Your Answer
Today: 13
This Week: 119
This Month: 495
All Time: 15,272
