Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Questions View all
Phone wet. Phone works, screen does not
The top of my iPhone 4S got wet and the camera flash stayed constantly on for a while. I out the phone in rice for a good while. I tried later to use the phone but the screen would not turn on. Although when I use Siri, it still calls and the speaker works. When I touch to hang up or power off, I can still use the touch screen. I'm just unable to see anything on the blank screen. I've tried resetting, but it has not worked. Is there anything I can do?
Score -1
Add a comment
Most Helpful Answer
oh, i suppose you have the same problem as this guy
dropped in water. Black screen except in sunlite. touch screen works
try under sunlight, if you can see something, then the same as above one, if not then your LCD is totally damage. but whatever it is partly or totally damaged, all you need to do is replace a LCD.
Hope this can help you. please vote if you like my answer, thank you!
Score 1
Add a comment
Ron, what is important here is to remember that you need to clean your phone properly. After any exposure to liquid, you are running the risk of corrosion damage/failure if you do not clean it up. Use these guides to work on your phone. Follow this guide to clean your phone. After that, replace the battery and reevaluate for any damage. It is possible that your display needs to be replaced, but do realize that this phone also requires a coil and IC's for the backlight. Hope this helps, good luck.
Add a comment
If you have warming zone in your oven put a cunductor on it like metal then put your iphone on top. Set the temp. on Hi and in a matter of time it will be ready and it might say that your iphone is to hot and it needs to cool down. to cool down DO NOT put it in the refregerator or the freezer just lay it down some were with a steady temp. HINT: when you put your iphone down on the conductor to heat always check your iphone every 2 minutes untill it works. (thank you reading hope this helped you like with other people!)
Add a comment
my iphone was dropped few days ago,.i put it in a warm place to get dry. when i charge it, it is recognized, vibration works, still doing the alarm. but the screen is black. i can operate touchscreen procedures, when i plugged it to itunes, the itunes required a respond from my iphone but i can respond because screen is black..any help please? important files inside.
Add a comment
Add your answer
Ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 11,097
