0
Score
Josh
Asked
Camera shutter will not open.
Ok so after replacing the front and back glass covers and replacing the camera I have been unable to use the camera app as the virtual shutter will not open.
I have tried covering the camera's, cancelling the app in the background run bar, soft and hard reset, settings>genera
Reading further about damaged jumper points on the logic board ( http://www.gsmindia.in/forum/apple-iphon... ), I have opened the device and inspected the logic board. Both sets of points seem to be intact for front and back cameras. I then checked for continuity in the jump points from the first picture (points near the front camera), and then the points from the second picture (near the rear camera) with a multimeter. The first set seem fine however the second set gave a high impedance (~100Ohm) in both directions. Should I remove the connector at the second point set and jump it with a solder bridge? Is there anything I'm missing?
Front camera points.
http://www.technicalnet.ch/iphone/Frontc...
Rear camera points.
0
Score
Brad
151
Answered
0
Score
finster
268
Answered
I think it's a bad idea. The logic board that you are seeing on these images are water damaged boards. So the values are maybe not good.
In this case I think the problem comes from Camera flex, maybe they're cut anywhere (micro-cuts). For my part, you have to change the camera and make cross test.
