0
Score
Asked
iPhone had a fall impacted top right hand corner
This question is archived. No new answers are allowed, and only the question's owner may edit it.
iphone had a fall impacted top right hand corner and now iphone keeps turning itself off :( i had the speaker replaced a while back and it was doin this after that as well but i releaised that the screws at the bottom were loose and that solved the prob then but not now?
any suggestions?
it works fine when its plugged in but works for a few mins when not on charge then just goes off
Pete Corbett,
battery loose maybe?
Pete Corbett,
the only way to test is to open the phone up. it sounds like a loose connector or broken power cable. The impact may just have widened the gap so no contact is made between the button hence it only works when plugged in. Try turning off energy saver/screen saver and see if that makes a difference. The battery connector is on the bottom 1/3 of the motherboard/pho ne so not a likely culprit.
pollytintop,
