0
Score
Asked
Destroyed Mechanism and continues clicking
I only had this camera for about a year when i dropped it, then i dropped again, now when i turn it on it clicks a lot and then it comes out partway then continues clicking and turns off
Edited by: oldturkey03 ( )
2
Score
oldturkey0
88.4k
Answered
Reagan Games, the clicking and churning noise is most likely your lens. It is possible that when it fell the lens came of the guides. Check on here for ideas on how to attempt to fix it. If those do not work, you most likely will have to replace the lens.
this is for Reagan Games :
You need to go and "edit" your original question
You get a window like this
Click on the orange tab marked "Images
a window will open on the bottom of your screen with an icon "Upload"
Click on that and then select the image you need to place on your original question
Once that image appears on the smaller window on the bottom left click and hold on it. Drag it into to edit area for your original question.
i want to tell you this, my brother already tried that and so we made it worse if you want i will make a video of the problem
Post an image of the mechanism in question on here. It will make it easier. You should remove the whole lens.....but let see what you got.
mostly of the internal part that you have trouble with. Preferably, if you still have it apart, lets see where you are stuck.
