Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Questions View all
Question Closed
Screen not working after fall, But digitizer still does...
Alright so my sister is clumsy and dropped her ipad, the screen shows nothing and once and awhile on a reboot for a split second goes blue and it is apparently the boot screen, it then goes totally dark. I have trouble shooted a little and found that it actually turns on and everything is working except the screen.
What I'm thinking is a connector or ribbon cable became unseated during the fall.
What's your opinion?
Add a comment
Chosen Solution
sounds like a back light issue to me.
1 of 2 things can fix this.
1. install a new screen assembly and its easy as that :)
2. the backlight IC is damamged on the mother board. this will entail that it needs an advanced repair done that requires very skilled hands.
try the first one and see if that works, but if not look on ebay or local repair shops if you need to do number 2.
Score 1
Add a comment
Try replacing the LCD only. Not the assembly. the screen isn't an assembly on the ipad 2 if these other two do not work.
1. Something similar happened to my friends IPhone and I just disconnected the lcd cable and reconnected, disconnected the battery, and it worked afterwards.
2. it might need a new display data cable only, but I'm not sure how that would get damaged during the fall
Add a comment
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 14
All Time: 1,038
